NI TestStand
How can i set the serial number for the report at run time
at the beginning of each test in TestStand i can write a Batch Serial number and for each test socket an UUTserial number (in the "Enter UUTs" Pop Up). The UUT serial numbers will be shown in the headline of the report.
During TestSTand is running, i call a LabView vi, which reads the serial numbers out of the memory of my UUTs and save it as a string to a parameter in TestStand.
Where i have to save the parameter, that it is shown in the headline of the report instead the serial number i have wrote at the beginning of the test.
Kind regards
Bastian
(5,325 Views)
Hi Bastain,
Assuming your using the Batch Process Model, you can programatically insert a new SN into the correct parameter in the postUUT callback sequence.
This sequence has access to the UUT.SerialNumber parameter so you can use a File Global to pass the SN from the main sequence to the postUUT callback.
Here is an example of what I mean.
Adam
(5,298 Views)
This should work for me,
as soon as I can create a file global.
There is a tab for sequence locals
And a menu for Station Globals.
It seems that my File Globals functionality is missing from teststand, is it in a special upgrade ?
(5,039 Views)
Found it in the View dropdown !
(5,037 Views)
