NI TestStand
How can i specify a StationGlobal using text and variables
i have two StationGlobals (numeric):
StationGlobals.One
StationGlobals.Two
And there is a FileGlobal.parameter (string) that contains the text "One".
How can i set an expression using something like:
StationGlobals.+FileGlobals.parameter = 12
So the second part of the StationGlobal is defined by another variable.
(2,648 Views)
StationGlobals.GetValNumber(Fileglobals.Parameter, 0)
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(2,627 Views)
Accepted by topic author OnlyOne
Sorry you probably want this:
StationGlobals.SetValNumber(FileGlobals.Parameter, 0x4, 12)
jigg
CTA, CLA
testeract.com
(2,624 Views)
solved.
thanks
(2,596 Views)
