NI TestStand
How do I Print Step Results depending on Variable?
I have a subsequence that generates an array, depending on a number of factors. For the final version, I'll print out ONLY the contents of the Array, into the report.
However, for debugging my subsequences, I want to Print out all of the results into the report. I want to be able to turn this ON and OFF, depending on if I'm debugging.
I've tried using a Parameter argument "Parameters.bPrintResult" and in the individual steps, adding:
RunState.Step.TS.NoResult = Parameters.bPrintResult
The results don't make sense to me in that if I run it, (True or False) it won't print, but if I use the "Set Next Step" it will print out.
Any words or wisdom?
Mike
(3,343 Views)
I can answer my own question...
It's just occurred to me that I've been through this once before, only in a slightly different context.
Turns out that the Process Model will pay attention to the ".NoResult" flag the NEXT time around.
I may consider some way of modifying the process model, but I'm not sure I want to spend the time.
Mike
Mike
(3,345 Views)
Hi Mike,
A really late reply so maybe you solved your problem already, but I wanted to write for the sake of completeness.
If you write
RunState.Step.TS.NoResult = (Step.Result.PassFail) ? True:False
as a post-expression for the step you want to delete the result (not as a separate step) then for that step no result is displayed in the log file if the step passes.
Message Edited by ebalci on 04-16-2007 01:34 PM
Message Edited by ebalci on 04-16-2007 01:38 PM
S. Eren BALCI
IMESTEK
(3,149 Views)
