NI TestStand
How do I access Teststand StationGlobals parameters from VB(6)
I've tried various incarnations of the AccessingPropertiesAndVariables example with no success.
(3,231 Views)
You will need to have the sequence context in your VB code, and access SequenceContex.StationGlobals.GetVal("MyLookupString"). This will return the data contained in the lookupstring. There is an NI example (attached file) that shows how to create a simple ActiveX DLL that is accessing a station global variable.
Roberto Piacentini
www.ni.com/support
(3,231 Views)
