NI TestStand
How do I change Our OI to rerun a sequence until terminated by operator?
On one computer our OI began terminating all sequences after one run of the sequence.  What do I need to change to get it back to running until terminated by operator?
(3,228 Views)
If you haven't changed anything from the default TestStand shipping behavior they would need to press 'Test UUTs' instead of 'Single Pass' on the OI.
Test Engineer - CTA
(3,225 Views)
We did change our OI, but I found that the problem was that I did not have the library that it referenced installed on the test computer, so it did not run fully.
Kurtus
(3,188 Views)
