NI TestStand
How do I detect a step's "Record Results" setting from C-Sharp
1) When the test execution is complete the AxApplicationMgr EndExecution event is raised.
2) My EndExecution event handler method stores the ResultList via a call to
myReport = item.GetValString("TS.StepName", PropertyOptions.PropOption_NoOptions);
3) Then I walk through each entry:
int numElements = myReport.GetNumElements();
for (int i = 0; i < numElements; ++i)
    PropertyObject resultData = myReport.GetPropertyObjectByOffset(i, PropertyOptions.PropOption_NoOptions);
    WalkTree(resultData);
4) WalkTree() is recursive, but eventually I get to a method with logic like this:
if (item.Exists("TS.StepType", PropertyOptions.PropOption_NoOptions))
    if (StepTypes.StepType_SequenceCall == item.GetValString("TS.StepType", PropertyOptions.PropOption_NoOptions))
        return;
    if (item.Exists("TS.StepName", PropertyOptions.PropOption_NoOptions))
        name = item.GetValString("TS.StepName", PropertyOptions.PropOption_NoOptions);
    if (item.Exists("Status", PropertyOptions.PropOption_NoOptions))
        status = item.GetValString("Status", PropertyOptions.PropOption_NoOptions);
    ... and so on ...
That's what we're doing.
Message 11 of 12
(719 Views)
Hi tlaford,
After reading the post again, I think the value you are looking for can be found here.
ThisContext.RunState.Sequence.Main["Statement"].TS.NoResult
You have to enable Show Hidden Properties under Configure >> Station Options >> Preference in order to see them.
I hope this helps.
Josh L.
Message 12 of 12
(699 Views)
