NI TestStand
How do I determine the execution entry point used programatically in a sequence?
I need to vary the behaviour (slightly) of a sequence depending on whether the user runs the sequence with the "Test UUTs" execution entry point or with "Single Pass".  I was hoping that I could find a variable to use in my sequence which specifies which entry point was used.  Is there a variable that shows this information?  If so, what is it?  If not, what other methods might work to accomplish this?
Sean
(3,672 Views)
In your MainSequence use the expression Locals.Caller = NameOf(RunState.Caller.RunState.Sequence).
(Locals.Caller declared as a string in the sequence.)
This will return a string to your variable as "Single Pass" or "Test UUTs".
Hope this helps
Regards
Ray
Regards
Ray Farmer
(3,670 Views)
Ray,
Thanks.  The string works just as you said, but I have two questions.
1) This string generates an error when the user runs selected steps (such as might occur when debugging a UUT).  Is there a way around that?
2) Is there a published list of "hidden variables" somewhere?  How did you find out about the "Runstate.Caller.Runstate.Sequence" variable?
Thanks again,
Sean
(3,659 Views)
