NI TestStand
How do I display the paramater values in the description field
In Teststand 3.1, I want to be able to show the paramater values entered when specifying the labview module in the description field of the sequence file.  How can this be done?
Message Edited by Guy04 on 11-30-2005 03:32 PM
(2,876 Views)
Hey Guy04,
Since LabVIEW does not have traditional function calls like C or C++ ( func(int a) ), this property is actually not supported for the LabVIEW adapter.  For most other adapters, this option can be set by going to Configure>>Adapters, select the adapter, and click configure.  If the option is possible, there is a checkbox to show the function arguments in the description.
Pat P.
Software Engineer
(2,851 Views)
