NI TestStand
How do I fill an array created as a local variable?
I have created an array of strings as a local variable and I want to fill this array with values.  How do I fill the array?  I tried using pre-expression to do this but I cannot determine the correct syntax.
 Is this the correct way of doing this or is there another method?
Message 1 of 11
(8,186 Views)
Have a look at the example AccessingArrays in the TestStand\examples folder.
The thing to remember is the index to the array is syntax as "[index]" eg "[0]" and similar 2d arrays its "[0][0]"
hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
Message 2 of 11
(8,179 Views)
Thanks for the help but, I couldn't get it to work.  I took a look at the examples and I could not find any example that used the indexing method as you described.  What I am trying to do is use the pre-expression to fill an array:  Something like this:
Locals.MyArray[0] = "String"
But this does not work.  Is there any method to do it inside of Teststand without calling a labview vi?
Thanks.
Message 3 of 11
(8,171 Views)
It works just like your example unless, of course, you have defined the array to be initially empty. In which case, you have to do a SetNumElements first. When you do it in an expression, do you get an error message? What's the message?
Message 4 of 11
(8,163 Views)
Thank you so much.  That is exactly what the problem was.  I was initializing the array to be empty.  Thanks a lot.
Message 5 of 11
(8,160 Views)
May I interject for a moment?
I think the question of syntax needs to be addressed further.
If you want to assign values to an empty 1D array, you can use "Locals.MyArray = {1, 2, 3, 4, 5}"
However, is there a way to assign values to an empty 2D array without having to assign each row separately?
Joel
Message 6 of 11
(7,840 Views)
Hi Joel,
Currently, while you can assign empty 1D arrays using the syntax you listed, you cannot use this syntax for empty 2D arrays.
I will file a product suggestion for this so it will be considered for future versions of TestStand.
Matt M.
NI
Message 7 of 11
(7,817 Views)
You can initialize arrays of arrays with nested array syntax:  locals.x = { {1, 2}, {3, 4}}
However, currently there is no equivalent syntactical shortcut for initializing a multidimensional array (which is not the same thing as an array of arrays).
For a multidimensional array, you could:
- set each element in the editor
- explicitly initialize each element (perhaps in a long comma separated statement)
- write a loop (which could copy values from a single dimensional array or an array of arrays you initialize separately)
- pass the multidimensional array to a code module and initialize it there
Message 8 of 11
(7,817 Views)
Are arrays of arrays a capability of a TestStand 3.1?  I don't currently see a way to create them.  All I see is the capability to create multidimensional arrays.  This brings up another question.  For practical purposes, can't a multidimensional array be thought of as an array of arrays?
At least when coding such in C, one would first allocate memory for the all the rows:
TestArray = calloc (numRows, sizeof(double*));
And then allocate each row individually, in a loop:
TestArray[i] = calloc (numCols, sizeof(double));
Then you would index an array element with two dimensions, TestArray[x][y].  So, unless TestStand handles this differently, I don't see how a multidimensional array is different from an array of arrays, conceptually.  If I have missed anything, I await further enlightenment.
Message 9 of 11
(7,776 Views)
Both in TestStand and C/C++, multidimensional arrays are different from arrays of arrays in that multidimensional arrays must be "square" (non-jagged) because element access is computed based on the full array dimensions. In contrast, arrays of arrays can be jagged. Element access is implemented by obtaining a reference or pointer to another array from a containing array, until you reach the last array which contains the elemental datatype.
To create an array of arrays in TestStand, create an array custom data type. Then create a variable that is an array of that custom datatype. By default your array of array will be "square", but you can resize individual sub-arrays to make it jagged.
Message 10 of 11
(7,772 Views)
