NI TestStand
How do I get ATML 5.00 reports to show CR and LF
TS 2012
Message 11 of 18
(2,284 Views)
@paulmw wrote:
Al B.
I was comparing the two "horizontal" stylesheets (my existing one vs. your new one) in Beyond Compare and experimented by reverting portions of your changes.  I reverted one section back to its origional and it is now displaying correctly in IE.  However, I do not understand all the functionality of XML/XLS so I don't know if I broke anything else.  This attachement is the Beyond Compare report of my modified version to your version.  Can you evaluate why it now works and supply a new set of stylesheets?
Paul
The exmaple sequence given above does display in IE with the modificaiton I descirbed in my previous post (quoted above), however I have a product XML report that still has some issues with the CR displaying in the report text.  It would appear that the section I reverted must cover displaying that report text but at least it now displays...  I think were getting close; just need to fix those few lines, is there some syntax mistake that IE is not handling?
Message 12 of 18
(2,280 Views)
By experimenting, I have determined that the reverted stection of the XLS pertains to ReportText that is from a test step (Pass/Fail, Numeric limit, etc).  So, that is why when I viewed one of my product reports with my modified stylesheet it was still messed up while the example sequence looked ok (it only has an action step).
Message 13 of 18
(2,277 Views)
Paul
In our testing we did not find any issues with the posted stylesheets.
Can you post an example sequence and the generated xml report file which shows the incorrect formatting.
Regards
Anand Jain
Message 14 of 18
(2,267 Views)
@Anand_Jain wrote:
Paul
Regards
Anand Jain
Here you go.  The Sequence is the same as before except it has two step types, both output report text
Message 15 of 18
(2,262 Views)
Hi Paul,
I did some testing, and found that I only get the behavior you describe in Firefox.  Please note that we currently only support the IE browser with TestStand reports.  If you are using IE, please send the exact version you are using from help>>about so I can test it (I tested with IE 6,8,and 9, which all worked).
Thanks!
Al B.
Staff Software Engineer - TestStand
CTA/CLD
Message 16 of 18
(2,244 Views)
@Al.B wrote:
Hi Paul,
Thanks!
Using IE 9
Message 17 of 18
(2,229 Views)
Accepted by topic author paulmw
Hi paul,
After further testing, the problem seems to be a security issue with windows.  On the stylesheets I sent previously, go to the properties window.  Near the bottom, you should see an "unblock" button.  Clicking this button should prevent this behavior.
Al B.
CTA/CLD
Message 18 of 18
(2,211 Views)
