NI TestStand
How do I get return parameters from a stored procedure call?
The Open SQL Statement has an option on the Advanced tab to specify a command type of 'stored procedure'. In addition to returning a recordset, a stored procedure can also return parameters (see http://support.microsoft.com/support/kb/articles/Q185/1/25.ASP for info on doing this with ADO). Is it possible to get those return parameters with TestStand? In particular, I want to be able to get error codes back from the stored procedure in case it fails (maybe there is another way).
(5,152 Views)
Yes. For each column defined in the Columns tab, TestStand will create a parameter. For output parameters, TestStand will retrieve the parameter value AFTER the statement has executed. Stored procedures can also a return a value in addition to output paramters. Set the Type under the Statements tab to Stored Procedures.
(5,152 Views)
The Open SQL Statement step type does not fully support stored procedures. If the procedure returns a record set than you can fetch the values as you would a SELECT statement. Stored procedures require you to setup the parameters before the call and this is not yet supported. Bob, in his answer, made a reference to the Statements tab and I think that he was talking about the Database Logging feature in TS 2.0.
If the stored procedure is returning a return value, it may return as a single column, single row recordset which can be fetched as you normally do a record set.
Scott Richardson
https://testeract.com
(5,152 Views)
Any idea when there will be support for output parameters? Stored procedures are much more useful when one can use the output parameters.
(5,152 Views)
Mark -
It is on our suggestion list, but it is not targeted for any specific release.
Scott Richardson - NI
Scott Richardson
(5,152 Views)
Does anyone know if this item in the suggestion list was implemented since 2002?
(4,614 Views)
Hi bmoyer,
Yes, this feature has been implemented for TestStand versions 3.0 and newer.
Jessica
Product Support Engineer
(4,576 Views)
