NI TestStand
How do I get rid of "error -17704", "CVI unable to save current project"?
This link describes the TestStand error I'm getting:
http://www.lctechnology.com/TestStand1
(3,472 Views)
I found no problem with debugging as outlined in
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/52f5bb7ae7f5a409862569ee0073ac53?OpenDocument
I used the AccessingArray example provided with teststand which was version 2.0.1 and CVI 6.0
I can see that you are using TS 2.0.1 by the dates of the TS entries in your project. What CVI version are you using?
Regards
Ray Farmer
Regards
Ray Farmer
(3,472 Views)
I've been following those directions exactly and I still get the error I described.
I'm using CVI version 6.0.0.
(3,472 Views)
Have you tried the process using one of the teststand examples. If you have a custom process model maybe switching back to the default.
Regards
Ray Farmer
Regards
Ray Farmer
(3,472 Views)
A reinstall of TestStand fixed my problem, thanks.
Bruce
(3,472 Views)
