NI TestStand
How do I handle a sting path with "\T"
I have a string path in TestStand that contains "\T"
Example:
C:\Program Files\Test
How can I stop TestStand interpreting this as a tab return.
Many thanks,
Shane.
(4,303 Views)
Accepted by topic author ShaneDonn
See this reply
Use integers if you can
(4,291 Views)
If the path is in an expression literal you need to escape your backslashes (backslash is the escape character so '\t' becomes a tab character). The path you specified should be:
"C:\\Program Files\\Test"
Now if you are storing the path directly in a string or path variable and not as a literal in an expression than you should NOT double the backslashes because in that case there is no unescaping being done.
I'm not sure what muks is referring to with "use integers if you can".
Hope this helps clarify things,
-Doug
Message Edited by dug9000 on 11-30-2009 09:43 AM
(4,227 Views)
