NI TestStand
How do I iterate using elements of an array in TestStand?
Juergen - Thanks for the post. Forgive me for all of the questions but I have never done this in TestStand before so everything I am seeing is new to me. This method that you propose seems to work for a fixed array. I am bring in a two dimensional array of strings from a Labview VI. This is a dynamic array meaning that the user of the test can specify any number of test configurations to run. The example before this one showed to be dynamic in that nature. I am not sure I completely understand the container aspect that you are using. If you wouldn't mind explaining I would appreciate it.
Message 11 of 16
(2,463 Views)
HI
The example was done as static. But you can resize it dynamically in your LabView code.
Take a look to this code snipped. It shows how you add a element to the container.
It is done in C# but the TS-Api Calls in LabView are the same.
Hope this helps
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
Message 12 of 16
(2,453 Views)
Juergen - I feel as though we are getting closer. I do not know C# so this is not really making any sense to me. I am going to come right out and ask. Would you be able to supply an example of how this is done between TS and LV? Again this type of interaction between the two I haven't messed with much. I went and read up on containers and now they make sense to me so I have have that done. Again in Labview this is a snap and I could go with that solution, I am just trying to use TS as much as possible and make my deployments not so LV heavy.
Troy
Message 13 of 16
(2,450 Views)
Hi Ray or asbo,
Would you please provide an example on how to add elements on typed containers.
On my private maschine i have no LV available and of course i am not very well with LV.
Juergen
--Signature--
Message 14 of 16
(2,447 Views)
hi,
I would like to have some solution...could you ls give me the olution
requirement is as follows
Array XX [ A_Temp,
               B_Temp,
               C_Oil Pressure,
               D_Oilpressure,
Note : A_Temp, B_Temp,C_Oil Pressure,D_Oilpressure all these parameters will be getting  numerical values (dynamically) from the simulink models and also in future I may need to add parameters to this array.
Array YY [A_Temp_1,
               B_Temp_2,
               C_Oil Pressure_3,
               D_Oilpressure_4,
Note : A_Temp_1, B_Temp_2,C_Oil Pressure_3,D_Oilpressure_4 all these parameters will be getting  numerical values (dynamically) from the simulink models
So my question :
I would like to verify A_Temp >= A_Temp_1
                            B_Temp >= B_Temp_2
                            C_Oil Pressure  >= C_Oil Pressure_3  etc
My teststand version is TS 4.2.1.83
I also tried usingforeachloop passing 2 parameters but it passes only one parameter in foreach loop...FYI
Message 15 of 16
(2,216 Views)
I noticed that you have a duplicate post here. Since this thread is over 2 years old, your new thread is more likely to be viewed by other users. We do not recommend creating duplicate posts because all threads are monitored and it reduces the effectiveness of answering your question.
Anjelica W.
Product Marketing Manager
FlexLogger and TestStand
Message 16 of 16
(2,198 Views)
