Home
Community
Discussion Forums
Most Active Software Boards
NI TestStand
Topic
NI TestStand
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
How do I load and run a sequence from the Tools menu?
Bob Balch
Member
01-12-2004
02:35 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
If I can build a sequence to do something special, what's the syntax required to load and run it from a menu? This must be transparent to the customer. I know how to add menu items, but the tools customize window seems to be looking for an exe.
0
Kudos
Message
1
of 2
(2,984 Views)
Reply
Re: How do I load and run a sequence from the Tools menu?
SachaE
Active Participant
01-13-2004
10:03 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
When you go to tools>>customise and then add in an item to appear in a menu, you need to select sequence, rather than command.
Hope that helps
S.
// it takes almost no time to rate an answer
0
Kudos
Message
2
of 2
(2,984 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
