NI TestStand
How do I make an OLE DB Connection from inside a .NET Action Step (C#)?
I'm trying to make a OLE DB connection to a MS Access file on my computer. I'm trying to do it by having a .NET Action Step in TestStand call a method that I've written in C# that makes the connection, queries the database, etc. I have attached a sequence file and C# code that illustrates what I'm doing.
When I call the method, I get this error (I have attached a screenshot of the error in TestStand):
System.InvalidOperationException: The 'Microsoft.ACE.OLEDB.12.0' provider is not registered on the local machine.
Why am I getting this error and how can I get around it?
I know Microsoft.ACE.OLEDB.12.0 is registered on my local machine because if I call the same method from Main() in my compiled C# code, it will work fine. There's clearly something different between when Main() calls the method and when TestStand calls the method, but I don't know what it is.
(1,897 Views)
Accepted by topic author Dana517
If it works in your C# app, but not in TestStand, you should probably double check that you are using the same bitness (32 vs 64) for both.
(1,862 Views)
That was it! It's 64-bit TestStand. In Visual Studio, I went into the Project Properties > Build and the checkbox was checked for "Prefer 32-bit". After I unchecked it, the same exception comes up outside of TestStand as well as inside. Which is fine. I can figure that one out.
(1,856 Views)
