NI TestStand
How do I open a microsoft word file using Teststand 2010?
Hi All,
I am currently using Teststand 2010. I need to do a simple task, at least I thought it was simple. I want to open a microsoft word file using Teststand 2010. I thought the using the "Call Executable" would be the first step, but I am not sure how to set it up. Any help would be greatly appreciated.
WJ
(4,345 Views)
You will actually need to use an ActiveX step to use Microsoft Word. I found this forum post with a similar question and an example. I opened the example and saved it to TestStand 2010 to reattach here.
Note: you will probably need to modify the "Open Document" step to make sure the FileName of the Word document matches the real file location.
Taylor B.
(4,314 Views)
