NI TestStand
How do I pass arguments to a TestStand sequence from an operator interface written in LabWindows?
I intend to use TS_EngineNewExecution() which takes a VARIANT parameter for the arguments.
I have only found example code for C++ where a propertyObject containing the arguments is converted to a VARIANT using the constructor of the _variant_t class.
How do I accomplish this in LabWindows?
Message 1 of 13
(5,851 Views)
Stefan,
Passing parameters to a sequence from a CVI Operator Interface is very similar to the C++ code you've seen. However there are subtle differences (as you already noted) when in comes to converting the PropertyObject to a Variant. Here is a function that contains the code you need to pass arguments to a sequence from CVI:
void ExecuteSequence(char *sequenceName, VBOOL useProcessModel)
ERRORINFO errorInfo;
int error = 0;
CAObjHandle modelSeqFile = 0;
CAObjHandle params = 0;
char *modelDesc = NULL;
LPDISPATCH dispPtr; // varible used to convert parameters from CAObjHandle to Variant
// get the model sequence file if needed
if(useProcessModel)
oleErrChk( TS_SeqFileGetModelSeqFile (gCurrentSequenceFile, &errorInfo,&mod
elDesc, &modelSeqFile));
// Create container that will hold two parameters. First parameter is a number, second is a string.
oleErrChk( TS_EngineNewPropertyObject (gEngine, &errorInfo, TS_PropValType_Container, VFALSE, "", 0,¶ms));
TS_PropertySetValNumber (params, &errorInfo, "Param1", 1, 45);
TS_PropertySetValString (params, &errorInfo, "Param2", 1, "This is a string");
// Converts CAObjHandle to Dispatch pointer
errChk(CA_GetDispatchFromObjHandle (params, &dispPtr));
// run the specified sequence in the currently loaded file
oleErrChk( TS_EngineNewExecution (gEngine, &errorInfo, gCurrentSequenceFile,sequenceName, modelSeqFile, VFALSE,
TS_ExecTypeMask_Normal,CA_VariantDispatch(dispPtr), CA_DEFAULT_VAL,
CA_DEFAULT_VAL, &gCurrentExecution));
Error:
if(modelSeqFile)
CA_DiscardObjHandle(modelSeqFile);
if(modelDesc)
CA_FreeMemory(modelDesc);
return;
Let me know if you have any questions,
Azucena
Message 2 of 13
(5,851 Views)
Is there an example to show how to populate the "seqArgs" parameter of the TS_EngineNewExecution call?
Message 3 of 13
(5,632 Views)
Hi webprofile,
I'm not sure that I understand your question given the previous post. These lines show how to populate the arguments into the newly created property object:
Message 4 of 13
(5,607 Views)
Hi James
Thanks for the reply.
I am trying to modify the OI code with CVI under:
C:\Program Files\National Instruments\TestStand 3.5\OperatorInterfaces\NI\TestStand 2.0.1 Operator Interfaces (Old)\Full-Featured\CVI
There is a CVI project called: testexec.prj. This has an engine.c file, and a function called:
TERetval Eng_BeginSeqExecution. Within this function, there is a TS_EngineNewExecution function call, and I am trying to pass parameters to the sequence using the arguments to the TS_EngineNewExecution call (in place of the CA_DEFAULT_VAL). How do I pass a parameter in place of this CA_DEFAULT_VAL?
The example shows passing the editArgs parameter, while the seqArgs and the interactiveArgs are default.
Message 5 of 13
(5,604 Views)
Hi James,
To add to the above post, I do the following in C#. My sample.seq file requires a string to be passed as a parameters to the file.
axApplicationMgr1.Start();
mEngine=axApplicationMgr1.GetEngine();
CurrentSequenceFile=axApplicationMgr1.OpenSequenceFile("Sample.seq");
NationalInstruments.TestStand.Interop.API.PropertyObject pobj=mEngine.NewPropertyObject(NationalInstruments.TestStand.Interop.API.PropertyValueTypes.PropValType_Container,false,"",0);
pobj.NewSubProperty("param1",NationalInstruments.TestStand.Interop.API.PropertyValueTypes.PropValType_String,false,"",0);
pobj.SetValString("param1",0,"This is a new message");
mEngine.NewExecution(CurrentSequenceFile,"MainSequence",null,false,0,pobj,null,null);
And it works fine. How do I do the same thing in CVI?
Message 6 of 13
(5,597 Views)
Hi webprofile,
I did not extensively test this code, but based on the previous posts, this is what the function might look like (I bolded the changes from what ships by default):
TERetval Eng_BeginSeqExecution(tSeqFileRec *seqFileRec, // must NOT be NULL
                               tSeqRec *seqRec,            // must NOT be NULL
                               ListType checkedStepList,
                               TEBool breakAtFirstTest)
    HRESULT res = 0;
    TEBool errorOccurred = FALSE;
    CAObjHandle newExeH = 0;
    VARIANT editArgsVar;
    CAObjHandle editArgsH = 0;
    oleErrChkReportErrInfo(TS_EngineNewPropertyObject (sTEEngineObj, &errorInfo, TS_PropValType_Container, VFALSE, "", 0,&params));
    TERetChk(CA_GetDispatchFromObjHandle (params, &dispPtr));
    TERetChk(CreateEditArgsObj(0, seqFileRec->seqFileH, seqRec->seqH, checkedStepList, &editArgsH));
    if (editArgsH) {
        LPDISPATCH editArgsDispatch = NULL;
        CA_GetDispatchFromObjHandle (editArgsH, &editArgsDispatch);
        editArgsVar = CA_VariantDispatch(editArgsDispatch);
    } else
        editArgsVar = CA_DEFAULT_VAL;
    oleErrChkReportErrInfo(TS_EngineNewExecution (sTEEngineObj, &errorInfo,
                                                  seqRec->seqName, 0,
                                                  TEBool2VBOOL(breakAtFirstTest),
                                                  editArgsVar,
                                                  CA_DEFAULT_VAL, &newExeH));
    /* we'll get this again later on the StartOfExecution event
     * so free this reference to it */
    CA_DiscardObjHandle(newExeH);
Error:
    if (editArgsH)
        CA_DiscardObjHandle(editArgsH);
    return !(errorOccurred || res < 0); /* return TRUE if no errors occurred */
Message 7 of 13
(5,585 Views)
Hi James,
I got it working with C#, but am not able to do it with CVI. Apparently, a property will not do it, I need to create a subproperty.
This is not the entire code, just a snippet.
Also, I get some warning that the handles to some of the variables I created (the seqArgsVar) have not been released. I guess in CVI, the CA_DiscardObjHandle discards the handles to the objects created. What is the equivalent in C#?
try
false,"",0);
false,"",0);
catch(Exception e)
MessageBox.Show(e.Message,"TestStand Error");
finally
mEngine.ReleaseSequenceFile(CurrentSequenceFile);
axApplicationMgr1.CloseSequenceFile(CurrentSequenceFile);
mEngine.ShutDown(
true);
axApplicationMgr1.Shutdown();
Message 8 of 13
(5,580 Views)
Hi webprofile,
Are you trying to write your program in CVI, C#, or both?
If you are using CVI, does the code that I posted above not work?
If you are using C#, there is no equivalent to release the property object since C# is a managed language. I pasted your code into the simple C# OI at:
OperatorInterfaces\NI\Simple\CSharp
and I did not receive any warnings when I ran it.
Message 9 of 13
(5,553 Views)
Hi James
Thanks for the reply. I am writing with CVI.
Message 10 of 13
(5,550 Views)
