NI TestStand
How do I programatically open a LabView Front panel?
Hi Paul,
I'm sure you're already figured it out as you mention, but for any other reader's of this thread, setting the value of said property in the pre-expression would cause the Front Panel to show as desired.  However, you could also use a previous step, or any other sequence which can access this step.  Let me know if you have any other questions on this one.  Thanks and have a good one.
Message Edited by Adam B. on 07-07-2005 01:12 PM
Message 11 of 12
(1,477 Views)
Adam,   Yes it works as expected.  I had worked with TS version 2 for about 4 years but I had forgotten that some things are hidden from mere mortals. We must have always run with them showing, cause I forgot all about how to enable them. Thanks again! I was getting frustrated.  One other thing I added to my vi is a simple vi-server call to see if my front panel is open. If it is then I enable a simple event structure to wait for the operator to click on a stop button before exiting. It all works very cleanly.  Paul
Message 12 of 12
(1,469 Views)
