NI TestStand
How do I programmetically determine whether the sequence is running in TS Runtime engine or Development version ?
You can check if your are running in the SeqEditor by checking a RunState property.
I think its called RunState.IsEditor, its a boolean. Its True if in the SeqEditor.
Check the Programmer Reference Help, there is a breakdown of the Sequence Context.
Regards
Ray Farmer
Regards
Ray Farmer
(3,374 Views)
Thanks Ray, It worked perfect.
(3,363 Views)
