NI TestStand
How do I read Additional Results from each step of my main sequence into LabVIEW?
I am working on creating custom stylesheets for TestStand reports. I am doing this by allowing the user to select the Additional Results from each step that she wants to see in the report in a LabVIEW edit substep. I can read the names of each step like in the attached image, but I'm having trouble accessing their (children?), the additional results.
(3,380 Views)
You can try GetFormattedValue after GetPropertyObjectByOffset. GetFormattedValue will get a number as a String.
If the type of property is known then use GetValNumber, GetValString and GetValBoolean for numeric, string and boolean respectively.
CLD
(3,373 Views)
Accepted by topic author filter5
I think I figured it out, I guess I hadn't tried everything. The solution is something like the attached. Thanks for the suggestion!
(3,369 Views)
