NI TestStand
How do I remove the Step name and result from the Report but keep the ReportText?
I wish to use OTF Reporting but only want to have the ReportText for the step and NOT the Stepname and Result logged in the Report. How would this be accomplished?
Thanks in advance.
RG
(3,223 Views)
I got the report to do what I wanted by modifying the report_txt.seq file......If there are better ways please pass them all.
Thanks.
RG
(3,210 Views)
You could use the ModifyReportBody callback sequence, especially if you what the reports only chaged for particular sequence files.
If you want all reports to have the same format then changing the report generation sequencefile is probably the right place to do it.
Regards
Ray Farmer
Regards
Ray Farmer
(3,206 Views)
Ray,
I'll take your advice and change the ModifyReportBody callback sequence since I don't want the change for all my sequences.
Thank you,
Ron
(3,202 Views)
