NI TestStand
How do I report #INF as a number
My test reports get sent to a database which refuses to accept non-numeric values (in this case #INF) where it expects to see a numeric value.  Is there a way to report INF as a numeric value such as 999?
(3,824 Views)
jd -
In general I do not recommend trying to replace INF with a valid value. What database are you using? Does your databases support NAN or IND because these might also come up?
If there are specific steps that are reporting this, you could update the sequence to change the specific values before they are added to results. For example, a post expression might be able to do this.
If you want to change the database logging schema, you will have to review the schema to find all the places where a INF numeric value could be logged and you could update the expression for the column to check for INF. I suspect you already know of one because you are getting an error. For example, if the numeric column expression is:
Logging.StepResult.Numeric
You could change it to something as shown below by using a conditional, but you need to decide if 999 is the correct replacement value:
(Logging.StepResult.Numeric == INF) ? 999 : Logging.StepResult.Numeric
Scott Richardson
https://testeract.com
(3,812 Views)
Thanks Scott,
I am unable to change the database logging schema.  It does not support NAN or IND either where it expects to see a number.
Let me give you more information, maybe you can help me in writing a post expression.  I am new to TestStand and don't have a lot of programming background, but...
Pre Expression in the case is:
FileGlobals.ResultCounter = FileGlobals.ResultCounter + 1,
Step.Result.Numeric =
FileGlobals.MultiResults[FileGlobals.ResultCounter]
Post Expression is empty:
Status Expression is:
Step.DataSource != "Step.Result.Numeric" ?
Step.Result.Numeric = Evaluate(Step.DataSource) : False,
(Step.Result.Numeric >= Step.Limits.Low && Step.Result.Numeric
<= Step.Limits.High) ? "Passed" : "Failed"
Thanks in advance for any input.
(3,797 Views)
jd -
It appears that you are using a step type that is custom and not based on the Numeric Limit Test step type because the status expression does not look familiar. Since the location of the value to evaluate is not determined until your status expression is evaluated, you need to update the status expression with something like the following in bold:
Step.DataSource != "Step.Result.Numeric" ? Step.Result.Numeric = Evaluate(Step.DataSource) : False,
Step.Result.Numeric = (Step.Result.Numeric == IND || Step.Result.Numeric == NAN) ? 999 : Step.Result.Numeric,
(Step.Result.Numeric >= Step.Limits.Low && Step.Result.Numeric <= Step.Limits.High) ? "Passed" : "Failed"
Hope this helps...
Scott Richardson
(3,751 Views)
