NI TestStand
How do I run a script saved under a diffrent name
Hi
I have a well working script that I expand with other features and save it with a different file name.. However this new script seems to fail due to that it somewhere still has a reference to the original script...
How do I go around this without having to rewrite everything...
I use TestStand v.3.1
Claus
(3,231 Views)
Claus,
I assume that by 'script' you mean 'sequence file'.
What are the changes you added to your new sequence file?
Why do you think your new sequence file has a reference to the original one?
Could you provide more details?
Best Regards.
Antonio Lie
Message Edited by Antonio Lie (NI) on 11-01-2005 12:29 PM
(3,228 Views)
Hi Antonio,
Thanks for your reply.. I could understand that the behaviour I saw in my .seq script was not a known problem, so I invetigated it further.. And I solved the issue 🙂
In a call sequence I had made it look in a specific file instead of "Use Current File"..
Regards
Claus
(3,216 Views)
I am glad you solved it.
Regards.
(3,211 Views)
