NI TestStand
How do I turn off the "could not find file" message for missing sequence files?
I moved my sequence file to a different directory.
Now everytime I open TestStand, a message box saying "Could not find file ''".
How do I get TestStand to stop reminding me that?
(3,157 Views)
To bmihura -
Can you be more specific:
1) What version of TestStand are you running?
2) Are you running the sequence editor or an operator interface? If an operator interface, which one, a TestStand one or a customized one?
3) Do you load a workspace?
4) Does the workspace automatically get loaded on startup?
5) Does the last opened file normally automatically get displayed on startup?
6) Can you attach a png/jpeg of the screen when this occurs?
Scott Richardson (NI)
Scott Richardson
https://testeract.com
(3,157 Views)
Scott,
You clued me in on the answer with those questions.
I'm running TestStand 2.0.1f1 from LabWindows/CVI 6.1.
I launch TestStand from CVI (which automatically loads a TestStand workspace) by filling in the box from CVI's Run >> Select External Process... menu as follows:
Program Name: c:\TestStand\Bin\SeqEdit.exe
Command Line Arguments: "C:\Bruce\ATP\Discrete IO Test.seq"
I had forgotten to change the path in the "Command Line Arguments" box.
thx
Bruce
(3,157 Views)
