NI TestStand
How do I work with binary string?
How do I specify binary string as a parameter value? Do I put that in quotes?
Let's say 0x21,0x02,0x27,0x01. I tried "0x21", "\0x21", "\21" etc. Keep getting "invalid escape character" error.
What should be a corresponding control in my VI? Should it be a string type?
How do I define a binary array as a local TS parameter? It seems I can create an array of 64 bit signed or unsigned integers. I'd need 8 bit unsigned or can I use string?
CT
(4,766 Views)
You should also know that there is a known issue with binary strings and LabVIEW adapter settings in TestStand 2010 and 2010 SP1. You can take a look at the list of known issues here.
Rohama K.
(4,737 Views)
I think the easiest thing for you to do is write a VI which returns the binary string as a parameter, check the checkbox in teststand when specifying that vi to say the parameter is a binary string, and run the sequence to get the string into teststand. Then you can see the format of the string and have a copy of it already in teststand that you can copy and paste if you so desire.
-Doug
(4,725 Views)
