NI TestStand
How do i release a Sequence file i opened with the Engine.OpenSequenceFile method?
I opened the Sequence file and used PropertyObject to pass parameters to it...
It is successfully runnung. but once i exit, I am getting a message that File ws not released.
I added the following code in the finally block
finally
mEngine.ReleaseSequenceFile(CurrentSequenceFile);
axApplicationMgr1.CloseSequenceFile(CurrentSequenceFile);
mEngine.ShutDown(
true);
axApplicationMgr1.Shutdown();
still the problem persists.
(3,017 Views)
From your code, it appears that you are doing everything correctly. In fact, I'm not sure that you even need to call mEngine.ReleaseSequenceFile.
Because you are creating a .NET object, you will need to do some garbage collection on those objects when you're done using them.
If you look at the TestStand OI, you'll see that a GC.Collect() method is called. This call forces .NET garbage collection. This should help you release your object.
Matt M.
NI
(3,006 Views)
Thanks Matt !!!!
I'll certainly try that if the problem persists!!!
(2,998 Views)
