NI TestStand
How do i terminate a sequence in my LabVIEW vi
I want to know how to terminate my TestStand sequence from LabVIEW. For example, I have the front panel of my sub vi show when that step executes in TestStand. I have a terminate button on the front panel, when it is pressed i want my TestStand sequence to terminate.
(3,649 Views)
Attached is a LV6.1 and TS2.01 example.
Hope this helps.
Regards
Ray Farmer
Regards
Ray Farmer
(3,649 Views)
Thanks Ray, Do you know if you do it the same way in TestStand 3.0 and LabVIEW 7.0? Thanks!
(3,649 Views)
Arj,
Yes, that example should run with out any problems.
Regards
Ray Farmer
Regards
Ray Farmer
(3,649 Views)
