NI TestStand
How do parameter files work with the NI IBM RQM Adapter?
I'm trying to figure out how parameter files work when executing a teststand sequence from IBM's RQM using the NI provided adapter.
So far, the only information I have been able to find regarding this is the brief section in the adapter's help file:
"Parameter files are files in the root resource folders that sequence files invoke. After you create a test script in IBM Rational Quality Manager, you can select a sequence file and parameter files for the sequence file. Before executing the sequence file, the Test Integration Adapter populates the list of parameter file paths into a TestStand variable named StationGlobals.NI_ParameterPaths.  To enable a sequence file to invoke non-sequence files in TestStand, you must create this variable in TestStand and specify the data type of this variable as an array of strings."
I have tried to follow this setup however the correct steps are not entirely clear.
- Will
I saw my father do some work on a car once as a kid and I asked him "How did you know how to do that?" He responded "I didn't, I had to figure it out."
(4,374 Views)
Will,
Can you provide any more detail about what went wrong when you tried to follow the snippet in the help file?
(4,302 Views)
