NI TestStand
How do you exclude individual steps from the report
I want to be able to exclude steps in the tests that give no added value to the report in teststand.
(3,519 Views)
Hi ADL,
Enter the Properties of the Step and in the Run Options Tab deselect the 'Record Results' control.
If the Step is a Sequence calls, then you could stop all result in that sequence by the Sequence Properties and enable the 'Disable Result Recording for all Steps'.
Hope this helps
Regards
Ray Farmer
Regards
Ray Farmer
(3,519 Views)
Hi ADL,
If you right click on the step and choose "properties" then click on the run options tab and de-select the record results check box near the bottom.
Hope this helps,
Nick
(3,519 Views)
