NI TestStand
How do you get a station global or any variable to be read across UUTs executing in the parallel Sequence model?
Dear  Support,
I have two questions regarding the parallel sequence model:
I am trying to find a global variable or any variable that can be universally read from any thread / step .   For instance:
- Parallel sequence Model
- 2 UUTs
- The main sequence has 20  steps
- I am looking for a variable that can be read universally across both UUTs in any step.  I have tried many, even the station global variable - as a Boolean - for "Abort" .  But that did not work either.
Question TWO:   How can I bring out this universal variable to the UI ?  Can you point me to an example?    Do I use the "Lookup"  ,.  I could not get that to work.  Can I use the "Label"  ?  I could not get that to work neither.
Thanks! Brad
Brad Whaley
LabVIEW Certified Engineer
(3,504 Views)
The station global should have worked since you are just reading a variable.
In case you are also updating the variable value you will need to save it also immediately after you modify.
(Engine.CommitGlobalsToDisk ( promptOnSaveConflicts = True)
(3,481 Views)
