NI TestStand
How do you populate your parameters with their actual names when calling a C++ dll file?
When I specify a module to be a C++ dll file, I get the error: “This function either does not have parameter information in the DLL or uses types not recognized by TestStand” when I select a function from the pull down menu.
One of my coworkers wrote a wrapper on top of a wrapper and it does not display the error, but still will not display the correct parameter names.  It will just populate the parameter list as arg1, arg2, etc...
Is there a way to call a C++ dll and make it correctly populate the names of the parameters?
(3,106 Views)
Hi Dusty,
Yes it is possible,
Check this Thread:
http://forums.ni.com/t5/NI-TestStand/Argument-for-function-not-viewed-able-under-VC-by-teststand/m-p...
Regards
Juergen
--Signature--
Sessions NI-Week 2017 2016
Feedback or kudos are welcome
(3,097 Views)
