NI TestStand
How does TestStand detect the active LabVIEW version
I have 2 version of LabVIEW installed: 2018 and 2020.
I've already setup LabVIEW 2020 to not update the windows registry.  So in windows explorer, when I double click a VI, LabVIEW 2018 gets launched.
But TestStand choose LabVIEW 2020 as the "active LabVIEW version".  Why?
How do I make TestStand choose LabVIEW 2018 instead?
George Zou
(1,951 Views)
TestStand chooses the last LabVIEW version which has been started successfully
https://forums.ni.com/t5/LabVIEW/Change-currently-active-LV-version-in-batch-script/td-p/2422008
(1,918 Views)
Is there a way to prevent LabVIEW Update that registry key?
George Zou
(1,903 Views)
Accepted by topic author zou
Not aware of one.
How about starting SeqEdit using a batch file?
Start the appropriate LabVIEW Version first, then SeqEdit?
(1,896 Views)
