NI TestStand
How does the OK button on the modelsupport2 interface start the execution of the socket?
I have a question. When I clicked the OK button on the interface of modelsupport2, I saw that it called an event callback:
QuitUserInterface (EVENT DLG DONE OK)
Continuing to track down, you can only see the initial definition of the function
I am not familiar with the code for CVI. Can anyone help me understand how it runs?
(1,562 Views)
Accepted by topic author angus2022
The dialog doesn't start the execution itself. Instead, the dialog is called through a Callback from the Process Model. This then sets parameters for each execution on whether they are enabled or not.
(1,521 Views)
Yes, you are right.
I tracked the process model this afternoon and found out how it drives execution. Now, I am further learning more information.
Thank you very much for your answer!
(1,504 Views)
