NI TestStand
How insert additional results from "SequenceFilePostStep" callback on the report
I'm trying to insert a value processed on "SequenceFilePostStep" callback on the report. But every try I did, using additional results, didn't work well. Anyone knows how to include the value processed after every step on the report? Thanks
(4,447 Views)
Please try the following :
In the "SequenceFilePostStep" copy the processed data to a stationglobal or fileglobal variable.
In the calling step properties add this variable in the additional result (properties-->additional results).
I checked with TS 13 it reports properly.
Since the "SequenceFilePostStep" is an engine callback probably it may not support updating the report .
Hope this helps.
Ravi
(4,419 Views)
