NI TestStand
How often do you use the List bar to Navigate
Hi Ppl,
I'm trying to build a custom sequence editor. In the Sequence Editor while the executions are run the sequence file view tab is open. So most of the time I use the tab's to navigate between sequence view and execution view. However in the full featured UI the sequence view is not visible while executing. So we have to navigate using the list bar.
I wanted to know will it be better to implement the way sequence editor displays the sequence view while executing. I can use a combo box to navigate to various sequence files and executions within the respective views. How often you guys use the list bar to navigate ?
Message Edited by lordsathish on 02-09-2010 12:15 AM
Message 1 of 1
(3,446 Views)
