NI TestStand
How to Create Test Sequence Document in HTML using command line
I have lot of sequences and I want to create Test Sequence Documentation in HTML format using Command Line automatically, is there a way to automate this task using .bat file or using   C#  .Net
(5,288 Views)
So I'm assuming you are talking about the Tool Menu item Sequence File Documentation...
That is calling the docgen.seq file located in the Components\Tools\DocGen folder.  There is a dll in there called docsupport.dll.  I'm sure you could just call that from C#?  Can you call C++ DLLs from C#?
Just a thought,
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(5,284 Views)
Error is thrown When I am trying to import the  docsupport.dll ,  cpould you provide an example how this can be called
(5,019 Views)
If you aren't able to figure out how to call a C++ DLL in .net then there may be another option.  Unfortunately I don't know how to do this off the top of my head and I don't have an example.
The other option would be to change docgen.seq a little bit to the dialog doesn't display and you just hardcode the options.  Then you can use a command line to call testexec.exe: http://zone.ni.com/reference/en-XX/help/370052K-01/tsfundamentals/infotopics/startup_opt/
Hope this helps,
jigg
CTA, CLA
testeract.com
(4,954 Views)
