NI TestStand
How to Deploy Station Preferences
I am deploying my application to my target PC along with the test stand engine. In the development PC, I have set few things in the station preferences like use computer name as station id. When I deploy my application. Does these station configuration also transfered to the target PC? If not how do I deploy the station preferences to the target PC.
Senthilnathan A.
(3,164 Views)
Hi Senthilnathan,
All your TestStand station configuration is stored in a file called TestExec.ini located in the <TestStand>/cfg folder. So if you'd like the same settings on your deployed computer, then you have to include this file into your TestStand Workspace. Now when you deploy, this file will replace the original settings.
I hope this helps
SijinK
(3,153 Views)
