NI TestStand
How to Edit Status Message to show Current Test Step Name in UUT Infromation Dialog Box ( ParallelModel - TestStand 2020)
I'm currently using TestStand 2020 with the parallelModel. I would like to display the name of the current test step (e.g. "Statement Step", "Wait 3 sec.", "Init Camera", "Check Voltage", etc.) in the "Status Message" column of the UUT dialog box that appears while test are running in parallel.
However, the Status Message column in the UUT dialog (where the serial number is entered) still displays only the default message: “Enter the next UUT serial number.”
Question:
• Where exactly should I place the code or modify the UUT dialog in order for it to show the real-time current step name for each Test Socket?
• Is it possible to update the dialog dynamically during test execution using this column?
Any help or sample implementation would be very much appreciated. Thank you!
(412 Views)
The source code is located at C:\Program Files (x86)\National Instruments\TestStand 20xx\Components\Models\TestStandModels\modelsupport2\paralleluutdlg.c
(371 Views)
