NI TestStand
How to Log Additional Data to the Batch Report Header ?
Is there a way to log additional data to the Batch Report Header just like you can log additional data to the UUT report:
TestStand Report Generation and Customization - NI
George Zou
(1,836 Views)
How do you do that?
George Zou
(1,794 Views)
I had the same problem,
may this can help you.
//Create Variable
#NoValidation(RunState.Root.Locals.UUT.AdditionalData.SetValString ( Locals.Results[Locals.DummyVar.iCtrArrayResults].Name ,  PropOption_InsertIfMissing, Locals.Results[Locals.DummyVar.iCtrArrayResults].State )),
//Add to Report
#NoValidation(   Evaluate(      "RunState.Root.Locals.UUT.AdditionalData."&Locals.Results[Locals.DummyVar.iCtrArrayResults].Name  &".SetFlags(\"\", 0,PropFlags_IncludeInReport)"        )     ),
 Best Rgds
MAGL21
(1,776 Views)
Thanks, which sequence should I add this statement in?
George Zou
(1,768 Views)
of cause, you need to adjust this statement according your case,
in the end you need to create a variable at this place:
And you need to set the falg of this variable via this command:
YourNewVariable.SetFlags(\"\", 0,PropFlags_IncludeInReport)
rgds
MAGL
(1,756 Views)
If I add it the main sequence, no error, but the additional header show up in the UUT Report, nothing changed in the Batch Report.
If I add it the PreBatch callback, I got an error: unknow variable or property name "RunState.Root.Locals.UUT".
George Zou
(1,756 Views)
