NI TestStand
How to Read and Write 2D Array from Teststand in Labview using Set and Get property Value method
Hi All,
I am trying to read 2D Array from from Teststand using  "Get Property Value"  VI Function in labview
but I am facing error.
Thanks in advance ,
SV.
Message 1 of 8
(3,784 Views)
Its Quiet Possible , using Get/Set Val variant (In Property Object).
Its always good to share the code you developed and the error you are facing to get the proper response.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 2 of 8
(3,765 Views)
i am using normal Teststand API Function to test.
Message 3 of 8
(3,758 Views)
You can create your own Module for this purpose in LabVIEW
Snippet to Set Value.
Message 4 of 8
(3,751 Views)
Is this function will set and Get 2D Numeric Array Value from Labview to Teststans ?
Message 5 of 8
(3,745 Views)
I have used and worked fine for 1D Array, same should work fine for 2D Array so that's the reason we used Variant instead of Specific type.
Message 6 of 8
(3,742 Views)
Yes , its works fine for 1D Array, but 2D Array it shows error
Message 7 of 8
(3,735 Views)
Checked and works fine Even for 2D Array. Please Make sure you have created Variable with 2D Array and Calling Proper Names.
Its Better to share the Code which you have tried for better update.
Message 8 of 8
(3,722 Views)
