NI TestStand
How to Read/write attributes of local variable of "Object Reference" type
How to access attributes of a local variable of "Object Reference" type?
Accessing attributes of a "simple" data type is easy an can be done by using the lookup string. "Locals.clusterData.Attributes.MyCompany.StringData".
See https://www.ni.com/docs/en-US/bundle/teststand-api-reference/page/tsapiref/propertyobject-attributes...
However when the local variable is of "Object Reference" type this does not work.
Message 1 of 15
(3,446 Views)
For me it worked the same way that it works when I access the fields of the ObjRef:
 Locals.objRef->field1
 Locals.objRef->field2
 thus,
 Locals.objRef->Attributes->attribute1
 Locals.objRef->Attributes->attribute2
Message 2 of 15
(3,406 Views)
Hi israel
I can't make it work. Could you please modify my example and upload?
Message 3 of 15
(3,381 Views)
I've figured it's possible to do like this: "Locals.GetPropertyObject("objData",0).Attributes.MyCompany.StringData".
In this case it's not possible to "browse" the attributes as if the local variable was not of "Object Reference" type.
Message 4 of 15
(3,377 Views)
Gladfully would,
But it seems that I can't open the file, because your version is newer than mine.
Can you please try saving it As a TS 2012-2013 format?
Message 5 of 15
(3,376 Views)
Appreciate it. TestStand 2012 version attached. Thanks in advance.
Message 6 of 15
(3,368 Views)
Hi, sorry for the delay...
A working file is attached.
Message 7 of 15
(3,334 Views)
Hi israel
Thanks for the reply but it was not what I had in mind. The function should work on the "Locals.objData" attributes not on the "Locals.clusterData" attribute. This was only included as an example of what I would like to do.
I've attached the example again with the "Locals.clusterData" removed.
Thanks in advance.
Message 8 of 15
(3,303 Views)
I get you now.
I thought you want to access the Local object's attributes using the Reference Object.
I tried several combinations but have come to a dead end, as for now I can't find a way accessing it, even though the TS lets you creating it.
But can I ask why you need the attributes on the reference rather than on the referred object itself?
Message 9 of 15
(3,261 Views)
The attribute give information regarding the object passed but the information is not (at time being) a part of the object. Adding the attribute is/would be a way to avoid changing the original object as i do not know where it is used and by whom (is a part of a test framework).
It is possible to access the attribute like this "Locals.GetPropertyObject("objData",0).Attributes.MyCompany.StringData" but seems not to be the right way.
Thanks for spending your time helping me
Message 10 of 15
(3,243 Views)
