NI TestStand
How to Release Engine-Object in COM-Server?
I'm writing a COM-Server (VC++, ATL) which uses among other things the
Teststand Engine-Object. Creating the engine and using it is no problem,
but if I release the engine I get an exception when my COM-Server is released.
If I do not call engine->Release() this does not happen. I've written a dummy
COM-Server, which only creates the engine in one function an releases it in
another function. When debugging it with a VB-Script I get an access violation
upon the release of the COM-Server if engine->Release() is called.
STDMETHODIMP CClass::Start()
    AFX_MANAGE_STATE(AfxGetStaticModuleState())
    HRESULT hr;
    // Load TestStand Engine
    hr = engine.CreateInstance("TestStand.Engine");
    return S_OK;
STDMETHODIMP CTest::Close()
    HRESULT hr;
    hr = engine->Release();
    return S_OK;
Do I have to release the engine object programatically? Is there a description
of an object release schedule, which tells me when and how to release Teststand
objects?
Thank you.
Mike
(3,114 Views)
have you tried calling
engine.ShutDown(true)
before closing the reference?
(3,094 Views)
