NI TestStand
How to 'Unload all modules' from a TestStand sequence
Does anyone know how to call a TestStand menu item from within a TestStand sequence?
Specifically I wish to make a call to 'Unload All Modules' as part of my sequence.
This is found under File -> Unload All Modules.
I'm using TestStand 3.0
Many thanks,
Ronnie
TestStand 4.2.1, LabVIEW 2009, LabWindows/CVI 2009
(5,291 Views)
You can try the following TS API methods
Sequence.UnloadModules() - this unloads all the code modules in a sequence
SequenceFile.UnloadModules() - this unloads all the code modules from all the steps in all the sequences of the sequence file.
Engine.UnloadAllModules() - Unloads all code modules assoicated with steps, step types and substeps.
Hope this helps
Ray Farmer
Regards
Ray Farmer
(5,286 Views)
Thanks Ray - these suggestions work great and I've since found out where thay are in the online help!
(5,269 Views)
