NI TestStand
How to Unload all modules
I am trying to unload all modules inside TestStand at the end of my sequence.
I want to do it using code and not manually doing it. But when I write in
RunState.Engine.UnloadAllModules() and run the program. It works properly but when running it the second time, I get an error saying "Error calling sequence |V|Driver"
Is there a reason for this or another way to unload all modules?
(6,479 Views)
Hi, you could try UnloadAllModules Method
Syntax
Purpose
Unloads all code modules associated with steps, step types, and substeps.
Remarks
Call this method to force all modules to be unloaded and then reloaded when they are next called so you can rebuild DLLs and other code modules. This method also unloads the station model sequence file. Typically, you only call this method when no executions are running.
(6,442 Views)
You are able to specify loading options for Sequence Files as a whole. In the Sequence File Properties dialog there is a drop down for steps to unload when the sequence finishes execution. This might be easier than having an API call in your sequence.
You can also specify the Loading option, so when it runs again you can have it preload all steps when it begins.
Is this method an option for you?
Nico
Nico
Systems Engineer
Certified TestStand Architect Certified LabVIEW Architect
(6,437 Views)
