NI TestStand
How to Use  PreUUT to Get the Mainsequence ResultList status value??
Does Anyone knows
Regards
(726 Views)
The PreUUT runs before main sequence call back. I don't think you can get Main sequence result in PreUUT callback.
Maybe you can check in PostUUT call back using sequence context.
(696 Views)
If you are using the default Sequential model for TestStand, in PostUUT you can access the client sequence file's results using this expression:
RunState.Root.Locals.ResultList[0].TS.SequenceCall.ResultList
In PreUUT you can only access the Root result list, which is empty because model has not yet executed the Sequence Call step to call the client sequence file.
Scott Richardson
https://testeract.com
(676 Views)
