08-31-2007 03:41 AM
08-31-2007 03:41 AM
08-31-2007 12:36 PM
My suggestion is that you set all your defaults for your limits for each step first. Then in the sequence go to Tools>Import/Export properties and export your limits to a spreadsheet. If you do this first they will be in the correct format. Then use the property loader step to import them back in during run time.
hope this helps
09-02-2007 11:51 PM
09-04-2007 03:16 PM
It wasn't your english I just misread the question. I found this link that might help answer your question.
http://forums.ni.com/ni/board/message?board.id=330&message.id=13163&requireLogin=False
Hope it helps.
09-04-2007 08:12 PM
