NI TestStand
How to access Sequence File hidden properties
Is there a way to know all the Sequence File (SequenceFile.Data) hidden properties???
So far I've been able to guess only a couple of them seeing the Sequence File as text, but I'd like to know all of them:
LoadOpt, UnloadOpt, Version, BatchSync
See screenshot...
(3,279 Views)
You can view hidden properties by going to Configure >> Station Options >> Preferences.  At the top will be a check box that will enable Show Hidden Properties.  Now you can view these hidden properties when you browse the Sequence Context.
(3,248 Views)
