NI TestStand
How to access Station Globals From a CVI OI outside a sequence?
Is there any method to acces Station Globals from a OI developped under CVI?
My base code is TestStand 3.5\OperatorInterfaces\NI\Full-Featured\CVI\TestExec.*
I want to acces to Station Globals directly from the user interface with boolean controls.
My code :
double State;
CAObjHandle propObj=0;
ERRORINFO errorInfo;
tsErrChk(TS_PropertyGetValNumber(propObj, &errorInfo, "StationGlobals.toto", 0, &State));
Error:
   DisplayError(error);
(2,915 Views)
If I understand your wish the right way, I suppose that you should fine what you need in the TS API. EngineGetGlobals or SeqContextGetStationGlobals should meet your purpose.
(2,889 Views)
