NI TestStand
How to access StationGlobals from "Application Manager"?
i´m using the default NI-Labview-OperatorInterface (with some modifications) which is located in the TestStand-Directory in C:\Programme\National Instruments\TestStand 3.5\OperatorInterfaces\NI\Simple\LabVIEW.
How can i access with theApplication Manager (via TestStand Engine) the  StationGlobals?
TFTC
(3,712 Views)
Do you wish to access the StationGlobals from the OI in a similar manner as you can in the SeqEditor?
If you obtain the reference to the Engine Reference using the ApplicationManager.GetEngine method then can obtain a reference to the StationGlobal by using Engine.Globals
Or if you can get the SequenceContext Reference then you can obtain access to the StationGlobals.
Hope this helps
Regards
Ray Farmer
(3,711 Views)
Hello Raym
i tried what you explained but i cant read anything from the Globals.
Please see attached screenshot if there is an error.
thx
(3,708 Views)
In your picture you already have the station global referance.  I don't think you need the "stationglobal" as part of the lookup string.  Try just, "ProjectParameter.TestSequence".
(3,691 Views)
Hi
Paul is correct. you dont need the StationGlobals as part of the lookup string because you already have a reference at that level.
Regards
Ray Farmer
Regards
Ray Farmer
(3,673 Views)
Hi paulmw,
thanks for the tip. Works great now.
(3,667 Views)
